...once in a while.
I am declaring victory over understeer(tho I may be deluded).
The first third of today's AX was first gear with the new B #1 cog......can you say throttle steer?....Want to pivot the car?... just select the pedal on the right.....but use care.
The scrub radius problems I had been experiencing are a thing of the past.
With the cantilevers mounted on 8 inch wide wheels, the turn in is crisp AND it hooks.
Steering effort is no longer an issue. I did loop the car at about 45-50mph...one of them decreasing space slaloms....shit. had a gud run going too...yada,yada
So, tighten the front AR bar or softer rear springs? Feel free to pick one.
Britian done gud at his first SCCA lash up......bout a second off door slammer TTOD. I was bout .75 sec back of him...I think.
