Ok.. I met with Jerry West of European Cooler Air. Seemed like a really nice guy and really knew his way around a 914.
First off, I need to say that I was mistaken when I said that his kits do not require cutting the front trunk. His kits do require cuts but they are much less invasive cuts than the standard DPD and/or VPC kits required.
He has basic KITS. All parts are FACTORY NEW and fabricated specifically for the kit. They also use flat multi-groove belts and pulleys.
1) Single condensor unit, rotary compressor, all hoses, and under dash evaporator unit.
With this unit the condensor sits on the floor of the front trunk and measures a measely 3" high. It is encased in a study metal case and has a dual speed fan with a pressure sensor that switches the fan speed, as well as a cut out swtich which is based on the "freon" pressure.
This unit delivers approximately 1700 BTU
COST : $1795
2) Same as above but Double condensor system
With this unit, a second short but wide condensor is placed in the engine bay pitched so that it get the benefit of the air being sucked in by the engine fan.
This unit delivers between 1900 and 2000 BTU. (Was specifically designed for use in "the south" where temps easily reach 100+ degrees.
COST: $2095 (this also includes a larger "serpentine" coil system.
*** He also has two under dash evaporator options. The base unit (that is included in the price of the kit) is a 3/4 length unit which goes from the passenger side over to just cross the center "hump" area. The second is a FULL length evaporator that goes fully from side to side (An extra $30 for the FULL length option).
In each case you get 5 directional vents, and if you have a center console it does NOT have to be chopped. It fits AROUND the console leaving it intact and visible.
As for the cuts in the trunk floor, they are minimal compared to the old style. You cut to make about a 3 inch flap, with the bottom edge being the piece that is still connected to the trunk floor, in the front of the trunk wall. This gets bent down to an angle of approximatley 20 degrees (just enough to make an 'air scoop' which funnels air into the condensor unit.
The second cut is approximately the same, but at the back of the unit to let the air escape as it rakes across the condensor.
He is supposed to be sending me the "INSTALL GUIDE" so that I can share it with who ever might be interested.
I saw pictures of the work he's done, and it looks Top Knotch! The components are Professional quality and none of it (and I mean NONE) looks like it was done by a hobbiest.
He was talking to me about some of the work he's done and its been on everthing from VW Bugs to Ferarris
If you're interested, please feel free to contact him directly ... You'll find his details on the web site (
http://www.europeancoolerair.com/). Just tell him that you heard about it from me (Doug Gault).
Hope this helps. It looks like this is what I'm going to go with. I like the idea of an OEM look but with all brand new parts and a less invasive install.
Let me know if you have any questions, and I'll let you know when I have the INSTALL GUIDE to share!
Thanks!
doug
PS... For those in the D/FW area, if you're looking for him to install it, that is an extra $1000.
D.
