Mueller
Apr 24 2006, 10:57 AM
I added "heat" to my cleaning tank (cheap harbor freight unit)
The heating element (and mandatory thermostat) and threaded bracket all came from Home Depot, I think the cost was less than $30 for the parts.
A hole was cut and the bracket welded to the tank.
There are 2 different type of elements, this one cost a few bucks more, but will not burn out as easily if accidently turned on without being submerged.
Solution is water with Castrol SuperClean (about a 10:1 ratio)
Thermostat set at 130° (goes up to 150°)
The trailing arm in the picture was in the tank for less than 2 hours...once solution reached ideal temperature, power was left on for about another 20 minutes and then shut off. I will be adding insulation to the tank at a later date.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
1970 Neun vierzehn
Apr 24 2006, 11:10 AM
Nice clean hardware, but from the looks of the pic, the fumes may be taking the "color" off your palms as well! BTW, where and how do you dispose of the used cleaning solvent?
Mueller
Apr 24 2006, 11:19 AM
QUOTE(1970 Neun vierzehn @ Apr 24 2006, 10:10 AM)
hahaha, nah, those trees have been that way for a while
I only brought the tank out to the front yard to do the cutting/welding....gotta keep the neighbors wondering what I am up to
For the solvent, we have a free local hazardous waste station. Once junked up, I'll let some of the water evaporate and then fillup the old cleaning solution containers and drop them off.
neo914-6
Apr 24 2006, 12:05 PM
Yeah but does it work on cloth diapers?
richardL
Apr 24 2006, 12:20 PM
Mike,
When you do that, does it screw up the bearings or did you remove them first?
R
Mueller
Apr 24 2006, 12:28 PM
QUOTE(richardL @ Apr 24 2006, 11:20 AM)
Mike,
R
Hi Richard, I removed the bearings first, the grease wouldn't stand a chance with the heat and cleaning solution.
Trekkor
Apr 24 2006, 12:33 PM
That's looks fantastic.
Good work.
KT
bondo
Apr 24 2006, 12:38 PM
Do you think the heat would benefit a tank filled with mineral spirits? I'd think it would just turn it into a fume/fire hazard.
Maybe next time around I'll switch to a water based degreaser.
John
Apr 24 2006, 12:50 PM
I didn't realize that SuperClean would take off paint like that.
Was it submerged?
Mueller
Apr 24 2006, 01:08 PM
QUOTE(JOHNMAN @ Apr 24 2006, 11:50 AM)
Was it submerged?
Halfway submerged, I had to "flip" the part....I can now add more fluid if I wish, I was doing "leakage" test 1st
There is an a-arm and other parts inside the tank at the same time.
Adding some
agitation to the tank would make it even quicker to remove the dirt/grease/paint.
Aaron Cox
Apr 24 2006, 01:19 PM
agitation - borrow twystd1's vibrator
McMark
Apr 24 2006, 01:53 PM
Mike, I gave you the wrong trailing arms. I need those back.
Mueller
Apr 24 2006, 01:58 PM
QUOTE(McMark @ Apr 24 2006, 12:53 PM)
hahaha, good try....Randal has those trailing arms...these are off the '73....as for wrong parts, yes, you gave me the wrong front struts...the pair you gave me are from an early 911 or a /6
McMark
Apr 24 2006, 02:13 PM
I told you I didn't know for sure they were right. My strut ID skills are sub-par.
Mueller
Apr 24 2006, 02:16 PM
Mark........is the sandblasting cabinet up and running??
what about the powdercoating oven???
I'm still on fence about powdercoating these parts or just using rust-oleum and bake 'em....
McMark
Apr 24 2006, 02:49 PM
Blaster is ready to go with glass bead.
Powder coater needs a couple hours of woodworking to build and someone to motivate me.
I have access to an IR heater temporarily.
Porcharu
Apr 24 2006, 03:34 PM
Hey Mike - have you thought about using some Biodiesel as a solvent? It is suppossed to be a wicked solvent and it has a high flashpoint.
356&914&912E
Apr 24 2006, 03:57 PM
Hey Mike
What size tank is that and what are the SKU numbers for the parts from Home Depot?
Thanks
Ron
Mueller
Apr 24 2006, 04:07 PM
QUOTE(356&914&912E @ Apr 24 2006, 02:57 PM)
Hey Mike
Thanks
Ron
Mine is the 20 gallon tank for $79.99...
HF Solvent/parts cleaning tanks I'm pretty sure I still have the original packaging stuff from the piece parts, I'll try and look for them this week.
Steve, no, I never thought about the biodiesel....I wouldn't even begin to think of where to buy it....
McMark
Apr 24 2006, 04:15 PM
Craigslist.
jsteele22
Apr 24 2006, 04:19 PM
Looks fun. As for using mineral spirits or other organic solvents, do NOT try that ! Heat will change them from merely flamable liquid to explosive vapors.
The Castrol Superclean, and also the Purple Power from FLAPS, is a water-based mixture of lye (NaOH) and (I think) Butoxy-ethanol. I'm sure the later helps emulsify grease (makes it soluble in water), but even just the Lye + water +heat combo will strip paint. Used to be used for stripping furniture. And as nasty as Lye is, you can neutralize it with Hydrochloric acid (HCl) and end up with saltwater (NaCl + H2O). Hydrochloric acid, for some reason, gets sold under the name Muriatic acid.
Randal
Apr 24 2006, 04:48 PM
QUOTE(Mueller @ Apr 24 2006, 12:58 PM)
No I don't.
They should now be sitting in Chris Foley shop waiting for the
complete re-strengthing process.
It took me about two hours to clean them before packing them up
and sending them to Chris. I like your process much better Mike!
Have you got new needle bearings for the two trailing arms, post Chris Foley Fabrication?
I kind of doubt I can remove and use the needle bearings that Brad and I put in my existing trailing arms. What do you think Mike?
McMark
Apr 24 2006, 05:15 PM
Randal, let's talk about trading uninstalled bearings for your installed set.
Randal
Apr 24 2006, 05:19 PM
Sounds good to me Mark.
I'll let you know Chris's schedule as soon as I hear.
Mueller
Apr 24 2006, 05:22 PM
if you got anything else that needs the treatment, just drop it off and I'll throw it in the tank with my stuff.....
Randal
Apr 24 2006, 05:53 PM
QUOTE(Mueller @ Apr 24 2006, 04:22 PM)
OH BoY!
crash914
Apr 24 2006, 06:00 PM
Castrol has a lot of caustic in it...
Hot caustic works the bomb on paint...That is what we used to clean our mixing tanks at Sherwin-WIlliams....
Mueller
Apr 24 2006, 11:34 PM
Part numbers:
heating element=CAMCO MFG. SKU#15597
universal element adapter kit= CAMCO MFG. SKU#15712
cannot find the package for the thermostat, but same brand and should be right with the other parts.
Brando
Apr 25 2006, 12:17 PM
If you go to Kragen you can also get a 5-gallon drum of "Carburetor Cleaner" for a few bucks. That stuff is some caustic shit! It'll eat 30-year old oil off of cam towers and carbon buildup on pistons like nothin. Just don't get any on your clothes or skin... It'll smell for a week, not to mention burn like hell. Best stuff you can find, unless you got some cleaners and solvents from the 60s and 70s lying around.
Dave Bell
Apr 25 2006, 01:15 PM
Mike....
That is excellent...
I have some trailing arms that I was just about to get at to do some restoration on... and I have one of those Harbor Freight solvent tanks...
I see a weekend project in my near future.
thanks for sharing this one.
- Dave
Mueller
May 9 2006, 10:40 AM
QUOTE(Mueller @ Apr 24 2006, 10:34 PM)
Part numbers:
I found the packaging for the thermostat= CAMCO MFG. SKU#15449
Aaron Cox
May 9 2006, 10:52 AM
so how long till we see heated solvent tanks in the club store mike? LOL
356&914&912E
Jun 14 2006, 09:22 AM
QUOTE(Mueller @ May 9 2006, 09:40 AM)
Part numbers:
Mike
I finally got to a town with Home Depot stores and collected the above three items. How did you wire it (240 volts)?
Thanks
Ron
Bishop, CA
Mueller
Jun 14 2006, 09:27 AM
QUOTE(356&914&912E @ Jun 14 2006, 08:22 AM)
Part numbers:
Mike
Thanks
Ron
Bishop, CA
The wiring diagram is on the thermostat packaging...and yes, I used the 240v since it's more effecient than the 120v
