QUOTE(trekkor @ Apr 26 2006, 08:28 AM)
The car looks pretty balanced already.
When you do start working out the suspension...Look out!
Good car. Good build.
KT
I was really suprised at how balanced the car felt. Its a fairly soft set up with 200 lb springs in rear, no rear bar, 21 mm front Welt bar and stock torsions. Lost my front Koni adjustables to non adjustable Bilstiens in the 5 lug conversion, but still have adjustable konis in the rear. I think the current softness actually was an advantage in AX. Quite a few other cars, not 914's) were lifting tires all the way off the pavement in those tight corners. I think the biggest improvement will come when I replace the Victoracers with either Hooisers or 710s on the car.
