krazykonrad
Apr 26 2006, 10:17 AM
when I turn the wheel either to the right or left i'm getting this low griding noise from the front end. usually not there at parking lot speeds but real noticalbe on the highway. when the wheel is straight there is no sound. I'm thinking wheel bearings?? or the rack and pinion needs some oil. There are no noticble leaks from the rack and pinion, i.e. no spots on the driveway, but i havent crawled under to carefuly check.
Any suggestions?
many thanks!
Konrad 72
P.S. I know its not tire rub. I'm rolling on stock 4.5/15's
Leo Imperial
Apr 26 2006, 10:20 AM
Check for loose nut behind the wheel.
Sorry, I am bored at work.
TROJANMAN
Apr 26 2006, 10:23 AM
Check the Wheel Bearings
dimitri
Apr 26 2006, 10:28 AM
Check around your steering shaft inside car, wiring rubbing? Dimitri
Tobra
Apr 26 2006, 10:35 AM
how wide are the tires, rubbing in wheel well(happened to me)
John
Apr 26 2006, 10:45 AM
Does it grind while turning the steering wheel, or while the car is traveling around a turn?
If the grinding is while the car is traveling around a turn, then I'm guessing that your front wheel bearings are loose, allowing your rotors to touch the brake pads slightly in turns.
krazykonrad
Apr 27 2006, 05:27 PM
Thanks for all he advice! Hopefully this weekend I'll get a chance to tighten em up!
jr91472
Apr 28 2006, 07:07 AM
This may sound crazy, but check to make sure that your speedo cable is not kinked or wrapper around the streeting column. I chased a crazy grinding/rubbing sound for weeks that would come and go - convinced it was the front brakes, wheel bearings, something.
Turns out that the speedo cable was kinked at a bad angle right at the point where it connects to the speedometer.
just a thought......
ptravnic
Apr 28 2006, 07:44 AM
I had this problem, noticed especially on the highway circular on/off ramps - was wheel bearings...
