I recently installed a 75 2.0 in my car which is a 74. The engine had been sitting awhile before I bought it, probably at least a couple years. After a clean up, the engine is now in the car and working fairly well with the exception of two small issues.
1. Stalling: It does this immediately after starting, and on deceleration, basically whenever the car idles. Happens maybe 1/3 of the time or so, and when it doesn't stall , the idle surges from almost dying (alternator light comes on briefly) to maybe around 1500 RPMs or so and back and forth a couple times before finally leveling off at normal idling speed. If left to idle by itself after stabilizing, it will idle forever.
2. Slight shakiness in acceleration in the 2-3K RPM range. Very smooth accleration at lower and higher RPMs.
Aside from these minor issues, the engine runs perfectly, with no trouble at highway speeds and has power far superior to the 1.8 I removed.
I already have the idle adjusting screw all the way out, so it's not just that simple. Anybody have any ideas on what's going on? Any help is appreciated. Steve
