nine14cats
Apr 26 2006, 03:44 PM
What vendor has the best price for the rebuild kits for Weber 40 triple throat IDA's? My Webers have been sitting on the shelf for 2 years and I should clean them up before I stick them on The Beast.
Also, what's the best solution to clean them up with?
Thanks,
Bill P.
TimT
Apr 26 2006, 03:49 PM
Bill, I may be the best vendor.. I think I have a set of rebuild kits leftover from when I converted to EFI..Ill run out to the trailer and check
Aaron Cox
Apr 26 2006, 03:53 PM
if tim is of no help...
try PMO, or piercemanifolds.
grantsfo
Apr 26 2006, 03:57 PM
Got mine from PMO
nine14cats
Apr 26 2006, 04:03 PM
Thanks for the quick response guys. If TimT has them I'll go with him first (gotta support the Club members!). If not, I'll look at PMO or try some of the local shops to see if anyone has them in stock.
Bill P.
LvSteveH
Apr 26 2006, 04:16 PM
I'd if Tim doesn't have them, I'd go PMO, some of the kits out there have poorly made parts, like acc. pump diaphragms that are not particularly fuel resistant.
TimT
Apr 26 2006, 08:11 PM
OK , I checked my trailer, I dont have two kits per se, but I do have enough gaskets, etc to rebuild a bunch of Webers. I only found one accel pump diaphragm though.
If you need two unadulterated kits try PMO, or Greenfield Foreign Auto in Mass. Though PMO is probably more convenient to you
sean_v8_914
Apr 26 2006, 10:48 PM
does anyone have tuning info for tripple throat IDFs? my tail dragger is running RICH. where to position the bypass screws?
TimT
Apr 27 2006, 02:57 AM
Generally, start with the by-pass screws fully closed, measure airflow, adjust screws so all barrels flow the same amount of air, then move on to the mixture screw
More info is needed... more than its "running rich"
Gary
Apr 27 2006, 07:00 AM
Maybe running triple throat IDAs? Nice review of basic tuing in
this thread on the Pelican Board.
