shaggy
Apr 26 2006, 06:33 PM
i have a dirty 2.0l case that wont come apart
im doing an entire rebuild and need the case opened to see what cam i have and for cleaning
there is some black stuff in the seams it kinda lookes cracked but its not moving
i was holding it by studs and had my brother pulling down ward as i had a friend hitting the seam with a rubber mallet and got no movement
from a said rail guy i heard use a propane tourch w/ a wide flame to loosen it up while pulling
any ideas?
-shag
Joe Bob
Apr 26 2006, 06:37 PM
Keep looking....ya missed a nut.
type11969
Apr 26 2006, 06:40 PM
make sure you've undone every bolt, even one will stop it from budging. There are some bolts in odd places that can get easily covered in gunk . . . under the crank where the flywheel joins it, under the crank where the pulley joins it, on the bottom of the case hidden amongst the fins, and of course the one hidden between the lifter bores on the oil cooler side.
shaggy
sure i didnt
ive had 5 different people look it all over when it was on my stand and everyone has said they are all out
-shag
type11969
Apr 26 2006, 06:43 PM
Hmm, does look like that engine has been rebuilt judging by the epoxy over the galley plugs and the brown goo along the seam . . . looks like it might be permatex 3H which cleans up pretty well with acetone. Try some acetone along the seams to see if it loosens the goo up, it might help.
Mueller
Apr 26 2006, 06:47 PM
QUOTE(shaggy @ Apr 26 2006, 05:40 PM)
sure i didnt
-shag
you need a block of wood and a couple of
shaggy
Apr 26 2006, 06:48 PM
acetone huh?
ill have to try that tonight cuz all the bolts you listed i can bemember taking out
the ones under the flywheel and pump i had to use a u-joint thing for
thank
-shag
Joe Bob
Apr 26 2006, 06:58 PM
There's one or two that require a DEEP SOCKET and you can't really see and are accessed via long extension....if I remember....been awhile since I tore down a T-4.
Jake Raby
Apr 26 2006, 07:00 PM
If the engine does not split super easily you have a nut left in place.... Do you have my video, I go over EVERY nut because tons of cases are ruined because of ONE nut!
bd1308
Apr 26 2006, 07:02 PM
NO SCREWDRIVERS
NO NO NO
b
McMark
Apr 26 2006, 07:20 PM
Try the acetone, but you missed a nut. Notice a trend here?
shaggy
Apr 26 2006, 07:28 PM
hahahahaha
ya i am noticing that
ill go look soon...
-shag
McMark
Apr 26 2006, 07:30 PM
Is your oil pickup loose in the case? If the pickup doesn't wiggle around that's the bolt you missed. It's very deep in the case and very very easy to miss since it's usually completely covered in sludge.
shaggy
Apr 26 2006, 07:34 PM
"Is your oil pickup loose in the case?"
ya...i dont know that that is...
care to explain?
-shag
jd74914
Apr 26 2006, 07:41 PM
My engine had all of the nuts removed and wouldn't budge. I needed to use the hammer and a block to get it open. It didn't split very easily at all. It took me a long time to get it open.
McMark
Apr 26 2006, 07:45 PM
Once you've removed the large round cover on the bottom of the case there is a tube which is where your oil gets sucked up by the pump. That tube should be very loose in the case. If it feels "attached" it probably is and there's your last bolt.
shaggy
Apr 26 2006, 08:33 PM
the oil pick up is loose in the case
it moves freely in all dirrections
i can hear/ feel the crank moving too is that means anything
on the driver side of the case(i dont know what cylinder #s corespond to what side)
there is a giant triple square bolt
does that have to come out?
other than that there are no bolts missed im sure of it
id use the acetone but my mommy isnt here to give me her nail polish remover and i dont have a sister...
so i guess im out to dinner and will stop and pick some up
-shag
p.s. there tons of rtv on the flywheel side of the case
the main seal is rtved in
and the flat spots have rtv on them and it was placed there it isnt excess
Click to view attachmentidk if this shows them at all but its a try
John
Apr 26 2006, 08:50 PM
Um,
You do have the OIL PUMP off, don't you?
I just thought I would start asking the obvious first and then narrow it down....
When did Mr Raby get back?
bryanc
Apr 26 2006, 08:52 PM
The triple square is the oil pressure relief spring, not related holding the case together.
Jake Raby
Apr 26 2006, 08:55 PM
He is not back yet....
Just working on my new site and pulling my hair out waiting for the changes to upload!
shaggy
Apr 26 2006, 09:06 PM
well i have acetone now
currently eating my food so soon ill be out there pouring that all over the seam
and yes the pump is off and what a PITA it was to get it off
-shag
John
Apr 26 2006, 09:08 PM
Well then welcome not back yet.
So.Cal.914
Apr 26 2006, 09:14 PM
How about giving us a pic of all six sides and we will let you know what is up.
It should not take and more than gentle persuasion to split the case so put that
framing hammer away.
And no blow torchs.
shaggy
Apr 26 2006, 09:35 PM
ya, ill take pics tomorrow
its dark out there now and im not sure how clear the bolts would be
-shag
sean_v8_914
Apr 26 2006, 10:23 PM
is that a nut I see bottom center?
shaggy
Apr 26 2006, 10:44 PM
i see end of crank
i think there WAS a nut and bolt there but i removed it
then under that i think is the endo of the cam, no?
im sure i didnt miss any there
-shag
G e o r g e
Apr 26 2006, 11:10 PM
did you get the lower of the 2 right behind flywheel location?
shaggy
Apr 26 2006, 11:24 PM
theres only one behind the flywheel its like 1''-1 3/4'' under the bottom of the mai seal
thats the only nut and bolt on that face of the case
unless theres one that i dont know burried in rtv but i dont think thats the case cuz the rtv isnt near the seam
-shag
messix
Apr 26 2006, 11:51 PM
QUOTE(shaggy @ Apr 26 2006, 10:24 PM)
-shag
look at very bottom of case by the lip for the bellhousing,looks like a stud and nut at the bottom of picture.
G e o r g e
Apr 26 2006, 11:52 PM
i meant here
edit: great pics mcmark
McMark
Apr 27 2006, 01:07 AM
It does look like a nut right here.
Brando
Apr 27 2006, 01:13 AM
Definitely give that case a good scrubbing with some solvent or a cleaner of some sort... Once you get a lot of the gunk off of there you'll probably find your missing nut, or two. The bottom ones usually are harder to see on an engine that's leaky.
shaggy
Apr 27 2006, 08:14 AM
maddeye:
ya i got that one for sure
mcmark:
that one im not too sure about in off to shcool now so itll have to wait until i get home
-shaggy
Richard Casto
Apr 27 2006, 08:17 AM
I split a case a few weeks ago (first time) and I went throught the same problem. I swear I searched for over an hour for a missing nut and didn't think I could find any. Went upstairs to create a "can't split case" post. But decided instead to search and read any other posts I could find. Everyone one said "you have a missing nut". Jake mentioned in an old post of one that is easy to miss. If my memory serves correctly I think it was not near the perimeter of the case and may have been near that large triple square you mentioned. At the time, I didn't think it was used to hold the case together due to it's location. I removed it and the case came right apart with a few wacks of a rubber mallet.
Someone needs to create a thread with photos of each and every nut pointed out that you need to remove to split a case and put it in the "classics" section.
McMark
Apr 27 2006, 12:02 PM
Here are all the case perimeter bolts. I only put an arrow to each bolt ONCE, even though the same bolt can appear in multiple pictures. There are 20 bolts holding the case halves together, not counting the big BIG through bolts.
Front Bottom
Click to view attachment Front
Click to view attachmentTop
Click to view attachmentRear Bottom
Click to view attachmentSide
lapuwali
Apr 27 2006, 12:47 PM
I vote this goes to classic just for McMark's photos.
Allan
Apr 27 2006, 12:54 PM
QUOTE(lapuwali @ Apr 27 2006, 11:47 AM)
Brian Mifsud
Apr 27 2006, 01:16 PM
Yes, thanks for that......HEY..I've got a great idea for a 914.Club revenue generator....
rewrite the crappy "HAYNES" manual (just engine section).. but use the graphics as provided on the forum.
McMark
Apr 27 2006, 01:19 PM
I remade my post into a Classic thread.
shaggy
Apr 27 2006, 04:02 PM
thanks for the pics mcmark!
i just got home and looked at my case vs your pics
and i didnt miss a single bolt...
-shaggy
bd1308
Apr 27 2006, 04:05 PM
time for the rubber mallet.
NO SCREWDRIVERS
b
Mueller
Apr 27 2006, 04:08 PM
QUOTE(bd1308 @ Apr 27 2006, 03:05 PM)
NO SCREWDRIVERS
b
rubber mallet??
be a man....use a softblow hammer or a sledge with piece of wood
McMark
Apr 27 2006, 04:45 PM
There are two pins inside that are often sticking points. They are located here. The case pictured is quite difficult to separate. I have to steel wool the pins and the bores so they'll slide together easier.
Flat VW
Apr 27 2006, 04:52 PM
The Shaggester just went to go do an alarm repair call, he will return soon.
THANKS for helping fellas,
John
John
Apr 27 2006, 07:08 PM
HEY MAN,
I recognize that case.
I hope it is or will work out for you.
It is nice and clean too.
Dead Air
Apr 27 2006, 09:06 PM
this one
see my ef'ed up progress thread
get jakes video
