QUOTE(Andyrew @ Apr 26 2006, 08:38 PM)
Progressives work with a two rate spring, The lower rate depends on the spring, and for the first couple inches of compression it is at the lower rate, the higher rate is when the car is under "load"
AFAIK there are no 180 lb progressive springs... you could look on ebay or whatnot... but I would just get 180+ for your car... What do you have on there now?
Andrew
Andrew,
I have what I think are 200's, they are real stiff. I realize with a V8 car I need the support but would like a little softer ride. on another note I have a 911 front suspension, are the torsion bars (brown) the same as the 914? The reason I ask is the front is stiff as well.
John
