BMXerror
Apr 27 2006, 09:01 PM
Hey guys. I want to go to pressed studs on my 4-lug 914, but I don't really know what length to use. That's not really a problem because I can always just measure the existing lugs. My real problem is that I need to know what taper lug-nuts I need. I found some on Tweeks that list compatability with about every stock prosche wheel, including the 914-6, but not the 914-4. Are they different? Are the VW lugnuts the same? If anyone has a quick answer on this, please lemme know.... because I'm lazy and don't want to do the research myself. Thanks.
Mark D.
Mueller
Apr 27 2006, 09:05 PM
ball seat, no taper (unless you have aftermarket wheels)
Mueller
Apr 27 2006, 09:06 PM
oh yea...the reason they do not list the 914/4 is that it never came from the factory with studs...
Cap'n Krusty
Apr 27 2006, 09:28 PM
QUOTE(Mueller @ Apr 27 2006, 08:06 PM)
Ahem ......... We ARE the studs .......... The Cap'n
hmeeder
Apr 27 2006, 10:45 PM
My car is quite studly.
If you are looking for plain steel lug nuts, Pelican sells them for around $1.75 apiece IIRC. Look for steels lug nuts here
Lug NutsYou can also get studs and lug nuts from
this guy. Just one of many places. I got my studs from him. If you will not be using spacers, I would recommend the 66mm for the front and the 72mm for the rear.
BMXerror
Apr 28 2006, 12:42 PM
cool... so I guess that means that the 911 nuts will fit on the 4 lug wheels with no problem. thanks guys. Now I can stay lazy.
Mark D.
Eric_Shea
Apr 28 2006, 02:31 PM
If you're talking about pressing studs into a 914 hub then 45mm Verbus is the stock length and stud for a 911. 911 bosses are 7mm thick and 914 bosses are 10mm. I don't think 3mm would be an issue, especially on a Verbus which is fully threaded.
