Hammy
Apr 27 2006, 09:39 PM
I've been stripping my engine bay and rear trunk in preparation for POR 15.
I've found the easiest way for me is to annihilate the area with aircraft stripper and then pressure wash all the dead paint away. Wire wheeling the dead paint throws the stripper all over my skin
So about 70 percent of the paint is gone. But there's little patches of paint left everywhere. I see pictures of engine bays completely stripped of paint, bare metal.
How do you guys do it?
Aaron Cox
Apr 27 2006, 09:50 PM
stripper. put it on thick. then put THICK painters plastic over it (think HEAVY drop cloth from homedepot). this keeps it from evaporating. let it sit all day. in the sun.
now, pull plastic off. throw away.
grab putty knife or scraper and go to town.
what didnt come off, needs to be wirebrushed or wirewheeled or sanded off.
AA
Twystd1
Wire wheeling wet stripper and paint mixture....
Bro... You crack me up......
In a good way.....
Twystd1
Hammy
Apr 27 2006, 09:54 PM
Do you lay the plastic directly on the stripper?
Aaron Cox
Apr 27 2006, 09:55 PM
QUOTE(Hammy @ Apr 27 2006, 08:54 PM)
no. you sandwhich our man alpha in between.....
ok... you put peanut butter between......
yup. right on top. keeps it from 'vaporating
Hammy
Apr 27 2006, 10:04 PM
Aaron Cox
Apr 27 2006, 10:07 PM
get out there youngin and get'r done!
Lou W
Apr 27 2006, 10:35 PM
Patience grasshopper,
Patience, It can take 2, 3 or more coats
rjames
Apr 27 2006, 11:11 PM
I found that the 3m pads in the photo below take off paint (and seam sealer) way better (quicker) then the wire wheels do. Home Depot sells a version that fits on a 1/4" drill and it works excellent.
So.Cal.914
Apr 28 2006, 12:30 AM
You didn't say if it is apart or not. If so sand blast it and be done with it.
Otherwise, what they said..
alpha434
Apr 28 2006, 12:35 AM
Screw the paint remover and use a sandblaster like everyone else.
Or acid dip the whole car!
alpha434
Apr 28 2006, 12:36 AM
OH!
Or you can use an orbital sander. That does the job pretty quick. On sale at harbor freight for 9 buck RIGHT NOW!.
Aaron Cox
Apr 28 2006, 12:55 AM
Hammy
Apr 28 2006, 01:04 AM
Yeah it's apart... Don't have a sand blaster or know anything about it.
I have a sander but don't have a clue where it is
Andyrew
Apr 28 2006, 02:35 AM
Prep for por 15?
dude... Way to much work your doin here..
Wherever your at... stop... Take some 24 grit sand paper and kill those little area's to nock them down.
You really dont want paint stripper on metal. because you have to clean it off.. and you dont want water on your bare metal engine bay...
Use the 3m pads.. they work better than anything i've used... if you want the job to be "perfect" but por 15 doesnt apply perfectly...so ya.
just get the loose stuff off, and seal it up with por 15.
Rusty
Apr 28 2006, 02:47 AM
QUOTE(Aaron Cox @ Apr 28 2006, 06:50 AM)
AA
Aaron speaks wisdom.
One thing I would add... take a utility knife and scratch the paint heavily before you apply the stripper. That will give the stripper a place "get under" the paint easily. A good cross-hatch will speed the process along.
Don't be a gorilla with the knife. You want to penetrate the paint, not dent the metal beneath.
hope this helps,
Rusty
Jeroen
Apr 28 2006, 03:56 AM
wirewheel and lots of elbow grease...
sean_v8_914
Apr 28 2006, 08:37 AM
step away from teh keyboard and git er dun
Eric_Shea
Apr 28 2006, 10:45 AM
Acid dip 'your' car...
ty914
Apr 28 2006, 02:03 PM
I have walked in your shoes man...my best friend in the garage has been my pneumatic die grinder and 2" roll-lock disc of 80 grit. It has saved the elbow from the grease...
Aaron Cox
Apr 28 2006, 04:00 PM
QUOTE(Eric_Shea @ Apr 28 2006, 09:45 AM)
yur mom acid dips her car.
spunone
Apr 28 2006, 04:31 PM
No matter what ya do it sucks and is a Pain in the arse
Elliot_Cannon
Apr 28 2006, 09:11 PM
QUOTE(spunone @ Apr 28 2006, 03:31 PM)
Arse? Hey dude this is America! The proper word is "Culo".
Cheers, Elliot
bjorn jacobson
Apr 28 2006, 09:26 PM
I'm doing the wire wheel/palm sander/paint stripper rout. Wish I'd have just ponied up the money to acid dip. If ya have the bucks thats the rout to go unless you like having paint dust in every orifice!
Good luck,
BJ
Trekkor
Apr 28 2006, 09:39 PM
Take note that Aaron has directed you to Home Depot.
AA You were listening
KT
