Just started to sort out the V8 conversion recently (now that Winter is leaving)
and I have a "unique" problem with the cooling system. The details are:
Corvette (three core) Radiator;
Two Large Lexus puller fans (thermostatically set at 170 F)
Completely shrouded radiator system
Vented through the bottom of the front trunk
Coolant line under the vehicle are 1" I.D. thick wall aluminum tubing
Rod Simpson Water Pump (modified inlet; grafted GM thermostat housing)
Engine is a Late Model Chevy LT1 with external thermostat housing
Thermostat is a 180 F unit; with three 1/8" drilled relief holes.
Also I have a pressure bypass coolant line from the closed side of the
thermostat to the inlet side of the water pump; just to make sure at start-up
I don't generate enough pressure to blow any hoses off the block/pump/etc.
The expansion tank is about two litre capacity and is mounted high in the engine
bay on ther passenger side; on the inlet side of the water pump.
Next to the expansion tank is an overflow/recovery tank that allows coolant to
be retained from the other tank, when engine cools it get sucked back into the
expansion tank (all seems to be working properly; photo attached)
Radiator Cap has a 16 lbs. pressure rating
Otherwise the system works great and cools very well; just a blow by problem
as outline below:
At High Speed / RPM's the expansion tank overflows into the recovery tank
(I am assuming) THEN the recovery tank overflows and blows off coolant into the
atmosphere. (All the while the temperature guage remains constant at 180-190F)
I am thinking the Radiator Cap should be a higher rated pressure (maybe 20 lbs)?
the other problem could be I still have AIR in the system, does anyone know if
this is how the system might react with air ?
ANY thoughts or suggestions are appreciated. In the meantime I must keep my
foot out of the throttle until I sort this minor item; so so disappointing with this
little V8 sitting over my shoulder !!! Thanks again
Allan
