ok, i spent 1300 dollars getting my trans rebuilt but shifting is still difficult. Getting it into first and second gear is very hard. Bushings were replaced as well. What else needs replacing to make it shift smooth and fast? thanks
Mueller
Apr 28 2006, 10:17 AM
want smooth and fast??
buy a honda !!!!
Have you followed the directions in the haynes manual for adjusting the linkage??
To double check the linkage/bushings for wear, have someone hold the shifter in place and then you crawl underneath the car and see if you can get the linkage to wiggle.
The Rennshifter supposed to help since there is a good chance the shifter itself is worn.
Dr Evil
Apr 28 2006, 10:24 AM
What Mike said. Make sure the linkage is adjusted correctly.
olav
Apr 28 2006, 10:57 AM
QUOTE(will @ Apr 28 2006, 09:13 AM)
What did the 1300 dollars include?
Did the shop take out and put in the tranny?
If so, I wonder if the cone screws on the shift shaft are tight and in the alignment holes etc.
blitZ
Apr 28 2006, 11:00 AM
I started having trouble with first and reverse this week. Adjusted the clutch last night, works great today. Check your clutch, might need to tighten the cable a little.
will
Apr 28 2006, 11:23 AM
QUOTE(olav @ Apr 28 2006, 09:57 AM)
1300 dollars includes removing the trans and replacing all 5 synchros, 4 bushings, replacing the main shaft and reinstalling.
double-a
Apr 28 2006, 11:30 AM
if those cone set screws are loose, there will be enough wiggle to make finding a gear near impossible... btdt.
i agree, make sure the shifter is adjusted correctly. it's a bit of a trial and error thing, even with a nice new rennshifter.
~a
srb7f
Apr 28 2006, 01:58 PM
Be sure to check the two bushings inside the knuckle right behind the firewall. I had one side of them explode on me which left me with a very similar problem several months ago.
will
Apr 28 2006, 03:53 PM
QUOTE(srb7f @ Apr 28 2006, 12:58 PM)
thanks everyone....I will check out the linkage and cone screw this weekend....
rhodyguy
Apr 29 2006, 12:16 AM
tail or side shift? 1 & 2, reverse is fine? if you want to bang gears buy a mustang or camero (no offense intended).
k
