QUOTE(bondo @ Apr 29 2006, 03:51 PM)
QUOTE(wbergtho @ Apr 29 2006, 03:00 PM)
I'm not so sure these cables come w/ any lubrication...(doesn't need any) and I think that there might be something wrong with that particular cable. I bought a pair of McMaster-Carr cables and they don't have any friction whatsoever...leading me to think that you might want to order a new one. I never had to lubricate mine. If this is a new cable to begin with, they will probably replace it free of charge. Their customer service is awesome!
Bill
Hmm, but they're both like that. It's not a lot of friction, but it's not totally free either. These particular ones are cablecraft brand. I wonder if there's a spec for what it's supposed to be. That's gotta be tricky to measure though.
Can you just flop your shifter back and forth in the neutral plane with little effort? I have a tendency to do that when I'm waiting for a light to turn green, and I'm pretty sure I'm gonna be annoyed by the extra resistance.
I have the identical (well 5/16") McMaster-Carr cables in mine. The shift handle most certainly will NOT flop around, so yeah, there is
some friction, but nothing I considered an issue. When I was driving the car on the track, I never thought "wow, that is a tough shift". The 930 trans I have is a notchy bastard as it is anyway, so I notice the effort needed to shift it, not the handle...
One thing that will increase the friction is a tight bend radius - funny that the low-friction shows a higher bend radius, that is most likely why. Do you have a tight bend in the cable near the back of the car? I looped mine out a bit to give a larger radius at the rear. A tight radius was noticeable at the shift handle.
If you just notice you can't flop it around in neutral while sitting at the lights, I don't think you would even get that with the low-friction brand. Any guided cable used for "power transmision" just won't work like that. To be that sloppy, you wouldn't be able to "push on a rope", which is technically what you are doing half the time.
