pete-stevers
Apr 28 2006, 10:43 AM
i have two vacuum oil lines on th e 3.0......
one with a small orfice to the rear of intake boot,call it A
...one with regular size hose from back of boot-call it B
two vacuum oil line contections on the 914-6 tank....
one at top of oil filler...call it C
and one at middle top of tank..call it D
so tell me which one goes where???
VegasRacer
Apr 28 2006, 11:45 AM
Show me what you want Pete and I will reply with a photo.
I think B --> C is right.
pete-stevers
Apr 28 2006, 12:59 PM
there is a moratorium on pics until i turn over the key....
the boot has been modified a bit....
the vacuum is beeing run off one outlet on the boot close to the fuel distributor...i one has the pencil sized orfice, the other has none...
by the way john i got it to fit nicely by dropping it all the mounts one inch....yippie
J P Stein
Apr 29 2006, 08:37 AM
Your 'D' on the tank is input from the engine breather....off the top of the motor.
Your 'C' on the tank is output for the tank.....a breather line hook up. I run this to a catch tank.....some just hook up a breather filter there....some use this as a return line to the engine air cleaner....this is the stock 3.0L method in a 9eleben SC.
*If* you're planning on doing autocross, the catch can is a gud idea.
