QUOTE(nick mironov @ Apr 29 2006, 09:43 AM)
I have a Holley 4-barrel and I use the metered vacuum port (no vaccum advance at idle). If you use manifold vacuum, you will get vacuum advance at idle. It seems that people are split over which one is best and experimentation with both is recommended.
It seems to me that the selection of metered vs. maniflod vacuum would also be dependant on the overall ignition advance you are using. I also have a stock GM HEI and have 11 degrees if initial advance, 20 degree mechanical advance with medium springs that are all ib by 3,000 rpm, and the adjustment on the vacuum advance canister is set at about mid-point. I have not experimented much with other combinations, but plan to do so.
What is your advance curve like?
Nick
I thought it was timed vacuum.
My advance is bone stock, whatever that is; with a touch of twist the dizzy until it knocks and then back a bit.
Mark
