914werke
Apr 30 2006, 10:47 AM
So thes are off the 1.7 that is the base for my 1911 build up.
Turns out the eng. recently got a rebuild as all the parts show to be
nearly new and fairly clean.
914werke
Apr 30 2006, 10:50 AM
looking at them noticed they had peculiar squish lines,
closer inspection showed that the builder used multiple head
gaskets probably to adjust the CR?
914werke
Apr 30 2006, 10:54 AM
does this occur due to head torque squeezing out the gasket?
Im sure multiple shims is a bad idea but does this occur evan with a single
gasket?
Click to view attachmentBTW: this whole Top end in EXCELLENT used shape is FS!
PM if interested.
BarberDave
Apr 30 2006, 11:07 AM
The only reason i can come up with for the P.O. to used multiple head caskets is a warped hed or somethine like that. Why rase the commpression by using more than one. We need all the H.p. these engines can develop not less. Some people even remove the shims at the bottom of the cly. and lap them to the block to gain some compression.
Dave
914werke
Apr 30 2006, 12:13 PM
Umm but wouldnt adding in this manner would LOWER CR by increasing combustion Volume?
Brando
Apr 30 2006, 01:27 PM
^ Correct.
My guess, PO/builder didn't know you could use shims between the case and cylinders to set deck height.
Apr 30 2006, 01:29 PM
QUOTE(Brando @ Apr 30 2006, 12:27 PM)
McMark
Apr 30 2006, 03:33 PM
I can't imagine a head gasket deforming like that if you only use one.
LvSteveH
Apr 30 2006, 03:57 PM
On the up side, it appears to have been sealing very well, and no messy sealants. Maybe we should all do it.
Bleyseng
Apr 30 2006, 05:23 PM
Leave 'em out and adjust the CR with base shims to 8.5 to 1 on that 1.7L.
jd74914
Apr 30 2006, 08:33 PM
QUOTE(SirAndy @ Apr 30 2006, 03:29 PM)
One of mine was. And they were only stacked singlely. It was way out of whack and petruded into the combusion chamber big time
norustscott
May 1 2006, 07:04 AM
Did all cylinders have the double gaskets? thought maybe builder doubled up by accident on a single hole...?
914werke
May 1 2006, 08:19 AM
QUOTE(norustscott @ May 1 2006, 06:04 AM)
Nope all of them
