I feel for you. I just happen to have my engine pulled from my 74.
Its a 2.0L but I'm assuming that the impeller housing is the same
or very close.
Don't start/run the car just yet.....
Here is front picture of the housing. (Minues front engine tin)
Click to view attachmentThe left side of the picture is the passenger side.
After looking at this closely and also looking directly down
the access hole I doubt if you got any oil on the actual front of the engine.
It looks like it will drop straight down through the impeller openings
and pool up inside the housing.
The plate with the timing mark guide is very close to the actual impeller
and for the most part would block oil from running behind the impeller.
Also, what I hadn't remembered is that the drivers side opening
in the housing is much higher and there is some internal ducting that
is part of the housing. Based on this, I think it is very unlikely that
you got any oil in the drivers side heat exchanger or flapper box.
You might want to pull the drivers side heater duct to verify though.
This also means you can't blast anything like cleaner through the housing
from one side and out the other. There isn't a direct path.
Also in looking at the fan and belt closely: (with half front tin in place)
Click to view attachmentThere is over an inch between the impeller blades and the edge of the impeller.
The belt would be under this. So it is quite possible that no oil has gotten on the
belt either.
There is a rather large lip on the edge of the impeller that could collect oil.
My guess is that the bulk of the oil if not all of it simply poured straight down
and didn't splash too much. It pooled up in the impeller housing until it
started to run out the passenger side heat exchanger and then poured
out the flapper box. Depending on how clean your housing was and how
well it fits the remainder of the oil might even run out the bottom of the housing
since it splits in half and the split is directly along the bottom.
It all depends on how the oil ran through the opening.
Was the car on jack stands in the rear when the oil pouring occured?
If so, then the oil wouldn't pour straight down and might hit the rim
of impeller and splash a bit.
If it splashed it would pool up in the tin and quite possibly get on the fan belt.
Worst case, all the oil hit the rim of the impeller splashed all over and half filled
the impeller housing and half filled the front engine tin.
AND, the engine tin fits well and still has tight seals and is holding the oil.
(unlikely, but possible)
Things to do:
You should be able to tell alot by leaning WAY over and looking down
from the top to see how much oil splashed around. Use a mirror and you
should even be able to see inside the impeller and the front engine tin.
(Use one of those mirrors on a extensible stick so as not to drop anything
else inside the impeller)
NOTE: If you haven't already remove the engine lid, it is easy and
there is no way you'll be able to get your head
back far enough to see unless you remove it.
Also, look very closely at the bottom and see where the oil dripped from.
Look for the highest wet spots.
Did the oil run out from the center of the bottom of the impeller housing,
the heater duct work/flapper box,
or did it run out from the bottom or edge of the front engine tin?
Clean all the oil you can through the passenger side opening.
Get a flash light and even look inside, you should be able to clean
it out pretty well as long as you have patience and take your time.
Use some sort of solvent as mentioned. more than likely at least
some of it will run out through the split in the bottom of the housing.
Knowing how much the oil splashed and where it leaked from
will be a guide as to what and how much to clean.
Don't be too quick to start it. Once you start it, any remaining oil will be flung
all over the engine, cylinders, and oil cooler which will attract dirt and
potentially make the engine run hotter.
--- Bill
