stephen7
May 2 2006, 01:50 PM
I bought a triad - sweet deal. But it mounts too close to the end of the exhaust to clear the rear of the car. Can I buy extensions or do I just start cutting up the back of the car. I need about 2 - 3 inches more clerance with the rear valance.
thanks
steve
blitZ
May 2 2006, 02:49 PM
What kind of headers are you attaching it to? Can you post a pic?
McMark
May 2 2006, 03:20 PM
You shouldn't need to cut. Something is not right.
Allan
May 2 2006, 03:21 PM
QUOTE(McMark @ May 2 2006, 02:20 PM)
I saw Aaron install his and didn't see a saws-all in his pile of tools...
Grimstead
May 2 2006, 03:25 PM
QUOTE(Headrage @ May 2 2006, 02:21 PM)
I think Aaron kept the valance off, that what I plan to do with mine...
Mueller
May 2 2006, 03:30 PM
Not enough info.......
muffler for heatexchanger??
dual outlet or single??
it is for a 2.0 correct, if heat exchangers??
stephen7
May 2 2006, 04:50 PM
stand by for photos.....
Rouser
May 2 2006, 05:02 PM
You may have to shim (with washers) your rear tranny mounts (I had to, due to the 911 Sport mounts) to lower the powertrain a bit for clearance.
Than you clone the notch on the valence panel for the right side (sabre saw will do).
rhodyguy
May 2 2006, 05:06 PM
with the 2 out the back you will need to notch the valance to put it on. that is if you indeed have early 2.0, type 4, heat exchangers.
k
Gint
May 2 2006, 05:11 PM
with all of the above.
I just got off of the phone with Dave at Triad. Whodathunkit?
Dave tells me he now has jigged up and can attach mild steel ends to even stainless 1.7 or 1.8 HE's so that you can mount one of his mufflers wth the older exchangers. But without that mod it won't fit on 1.7 or 1.8 heat exchangers. All things being equal though, it should fit behind the valance with no issue. Unless of course you have the dual outlet Triad in which case the valance will have to be modified for the right side exit as has already been pointed out.
rhodyguy
May 2 2006, 05:20 PM
i hate the thought of taking my heat exchangers off and on to install a muffler setup. does anyone know if the 1.7/1.8 and the 2.0 used a common stainless outer skin?
k
stephen7
May 2 2006, 09:21 PM
I love the club!
Her are the pics
I have a 2.0 type IV from a bus I am told. here are some pics
this is what came off of it and this is what I have to put on it
Thanks
steve
Aaron Cox
May 2 2006, 09:23 PM
wrong HE's buddy. those are 1.7/1.8
triads ONLY FIT 2l heat exchangers.
Aaron Cox
May 2 2006, 09:24 PM
DanT
May 2 2006, 09:26 PM
those are 1.7L heat exchangers and if the muffler you bought was for a 2.0L it wont fit properly. 2.0L heat exchangers come straight out. No kick up like the ones you have
well I almost got it first Aaron
stephen7
May 2 2006, 09:33 PM
a ha
so maybe I don't have a 2.0 bus motor after all...
Is it correct to assume the 1.7 heat exchangers don't fit on a 2.0 engine?
(nice work on the photo redux btw)
thx
DanT
May 2 2006, 09:36 PM
Nope, not correct. 1.7 heat exchangers will fit a 2.0 so you could have either engine.
Aaron Cox
May 2 2006, 09:37 PM
QUOTE(stephen7 @ May 2 2006, 08:33 PM)
a ha
thx
all the heat exchangers will fit on a 1.7/8/2.0 motor.
they all fit the same...
the difference is ID, and the end where they kick up at the end (1.7/8) or stay straight (2.0)
the muffler hangers are diff.....
you could have a 2.0 with 1.7 HE's
Dan beat me this time....
DanT
May 2 2006, 09:41 PM
gotcha!
stephen7
May 2 2006, 09:43 PM
awesome input gents
you just saved me cutting the whole back end out of the car.
so -
is it safe then to conclude that I need the straight heat exchangers in order to mount this unit?
I bought this thing without knowing too much about it - it is worth putting it on right? better sound, mild horse power improvement -
no?
thanks
Aaron Cox
May 2 2006, 09:44 PM
QUOTE(Dan (Almaden Valley) @ May 2 2006, 08:41 PM)
gotcha!
you won the battle little dude.... but you lost the war
DanT
May 2 2006, 09:47 PM
war?? did I miss something?
And who says I am little?
Aaron Cox
May 2 2006, 09:48 PM
QUOTE(Dan (Almaden Valley) @ May 2 2006, 08:47 PM)
just a stupid quote from home alone....
lol. dan. "why cant we be friends, why cant we be friends"
DanT
May 2 2006, 09:50 PM
No problem....just dishing a little bit out, instead of taking it for a change
stephen7
May 2 2006, 10:02 PM
QUOTE(Dan (Almaden Valley) @ May 2 2006, 08:50 PM)
So - waduyouthink? Just find some heat exchangers that are straight? I don't have any heat in this car by the way. Does that matter?
It is strictly an autocrosser
merci bien
steve
DanT
May 2 2006, 10:05 PM
either you find a set of 2.0L SSIs or stock heat exchangers. Or you get yourself a muffler that works with 1.7L heat exchangers. Or get rid of it all and get some headers. What you have heat exchanger wise will not work with your Triad.
stephen7
May 2 2006, 10:09 PM
QUOTE(Dan (Almaden Valley) @ May 2 2006, 09:05 PM)
Thanks guys - you saved me a lot of agony
Gint
May 2 2006, 10:13 PM
QUOTE(stephen7 @ May 2 2006, 10:02 PM)
merci bien
steve
I'd buy a header if I didn't want heat. You could keep those HE's and have Dave at Triad modify them if you ever want to go back to heat.
swood
May 2 2006, 11:59 PM
QUOTE(Aaron Cox @ May 2 2006, 08:24 PM)
Dude, you drew dual dongs on that ass end...wassup widat??
jasons
May 3 2006, 12:10 AM
QUOTE(stephen7 @ May 2 2006, 09:09 PM)
You should just unload that POS Triad... I would be happy to take it off your hands and make sure it is disposed of properly on the ass end of my car.
Seriously if you decide to back out of it lemme know, I want one.
stephen7
May 3 2006, 02:55 AM
maybe - what is it worth to you? I heard I could get a used header for around $250. How do the triads sound? I am driving without any muffler right now and it sounds like I am driving a cessna 172 with the pitch turned all the way up and throttle all the way open. (Sounds tough) steve
type47
May 3 2006, 05:42 AM
i think you should verify that you have a bus engine, not that it makes a huge amount of difference with your exhaust situation. for future work and parts purchase, you would want to know. my bet is you have a 1.7L 914, not "bus" but the person who told you this may just have been referring to the motor as the same engine as is in the bus, since it "basically" is the same.
jasons
May 3 2006, 07:34 AM
QUOTE(stephen7 @ May 3 2006, 01:55 AM)
Whats the story on it? Condition etc....
I'll open an offer at $175
