QUOTE(Jake Raby @ May 2 2006, 10:06 PM)
LEAN!
and it's been detonating... Look at the deposits on the porcelin on the top pic...
Yea i was afraid of that. I had a feeling those specs meant something
I have Magnecore wires. After I changed this plug it was firing properly. Not sure why this plug wouldnt though...
I'm using those screw on ball adapters going to a standard spark plug wire connector. I'm good right?
Detonation is caused by a lean AFR. Lean leads to an increased combustion chamber temps causing detonation, right? Will timing that is too advanced cause detonation as well? I'll check it again, even though i just did and set it to 27degrees BTDC. Maybe my advance mechanism is stuck, i'll look into that too.
