EMMY 914
May 3 2006, 06:18 AM
I would like some ideas and pictures of a recommended latch to use the cut down refector on my 1975.
So if anyone could help I would graitful.
Emmy
TINCAN914
May 3 2006, 06:37 AM
You can use the the stock latch system for locking the trunk, but unless you want to cut a hole in the reflector, you can't use the push button (technical term?).
You can however buy a trunk release cable / set-up threw Engman, (screen name). If I have completely confused you, PM me and I will send some pics..
Van914
May 3 2006, 08:49 AM
I learned the hard way on this. I also have a cable that goes from the latch through the botttom of the trunk for a backup. Don't ask you don't want to know what happens when the cable release comes loose.
van914
tat2dphreak
May 3 2006, 09:00 AM
I plan on using the engman cable release... good stuff!
iamchappy
May 3 2006, 10:08 AM
I purchased a manual choke cable for mine and installed it. it works just like Engmans kit but only cost me 15.00. I did use the electric solenoid bracket to make it easy but also you can drill and tap a set screw into the exiting latch to make it work.
szuccaro
May 3 2006, 10:32 AM
Robert21
May 3 2006, 01:31 PM
Engman ,s cable release is great works everytime, bulid strong
and easy to put in . He sells good stuff.
Robert
Air_Cooled_Nut
May 3 2006, 07:58 PM
QUOTE(szuccaro @ May 3 2006, 09:32 AM)
It goes thru the center of the trunk? Yuck! Please tell me it can be routed along the side of the trunk and thus hidden. I did that with my mechanical release.
iamchappy
May 3 2006, 11:13 PM
Manual Choke cable at your local flaps, Im telling ya they work great and it's long enough to run around the sides of the trunk with the wiring. I mounted my
pull in the same place as my engine lid pull as I pinned my engine lid and didnt need it.
Engman
May 3 2006, 11:33 PM
Mine runs around the side of the trunk and mounts below the park brake.
See the resourses section.
M
szuccaro
May 3 2006, 11:38 PM
QUOTE(Air_Cooled_Nut @ May 3 2006, 06:58 PM)
Why Yuck? It can be routed along the side, but requires more work/time during installation... ie.. drilling. Your choice. I chose to run it on top of the carpet vs underneath to ensure no obstructions.
