QUOTE(Dr. Roger @ May 5 2006, 12:39 PM)
QUOTE(marks914 @ May 5 2006, 01:14 PM)
What you need is an IMI gear reduction starter for a 911/914. They will turn over a hi comperssion engine, but sometimes the end needs some reinforcement. They run $150-180 .
Mark
Mark,
Does my flywheel/ring gear look compatible with the starter you suggest?
I looks like a Renegade setup. Where did you get it? You could send some pics and measurements to Renegade and Kennedey to find out for sure.
Usually the flywheel is a 914 unit with the chevy pattern for the crank.
Either setup will use the IMI starter.
Be wary though, I bought a V8 flywheel from someone and it ended up being for a Bug, which bolted up OK but kind of bessed up the starter and flywheel.
Go here:
http://www.hitorque.com/Mark
