QUOTE(turboman808 @ May 5 2006, 08:46 PM)
I want one!!!! How would you hook that up? The car I got doesn't have the speedo working because of some tranny mod. How can I hook up one of these electronic???
I really want to do this
First, buy an electronic speedo. VDO makes them, as do Autometer, and the other usual suspects. They're fairly expensive ($200-ish), but can be used with a wide variety of senders and calibrated on the fly to many different wheel diameters and pulses per mile setups.
The sender can range from a $5 homebrew setup using a Hall Effect transistor sender (non-latching type) and a magnet on the diff output flange, as I mentioned above, to an auto-grade threaded body sender ($50-ish) that will do the same thing, but more reliably, to a sender adapted to the speedo output on the gearbox, as Clay pictured.
The advantages are: no more cable to snap and make noise and be a pain in the arse to install or get wrapped around the clutch or throttle cables; speedo has a smooth action with no bouncing; nice LCD odo/tripmeter that doesn't break; easy recalibration if you change tire sizes.
The disadvantages are: expensive; gauges generally aren't a good match for the other gauges on the dash; you lose any indicator lights in the speedo (like the high beam indicator), which have to be moved elsewhere.
