Hammy
May 5 2006, 09:29 PM
Mounted the pump today. Is this the right spot? I judged by pictures I've seen but I also read your pump needs to be lower than the tank (?).
Is that even the right filter to use? This is what they recommened at Napa.
I put some gas in and ran the pump and there was no leaking anywhere. so just making sure, did I get everything right?
Dave_Darling
May 5 2006, 10:02 PM
If you have carbs, that filter is OK. If you have fuel injection, that filter is not. It is not made for high pressure and flow, and will either clog up quickly or burst. Not happy, as you can imagine.
The location is OK as well. That is more or less in the factory location, which worked pretty decently.
(Looks like someone got a little bit POR-15-happy!!)
--DD
Hammy
May 5 2006, 10:05 PM
QUOTE(Dave_Darling @ May 5 2006, 09:02 PM)
--DD
Thanks Dave. Yes it's for carbs.
Yeah I definitely went AWOL with Por-15.
planning on making it a daily driver/rain car...
Gint
May 5 2006, 10:38 PM
QUOTE(Hammy @ May 5 2006, 10:05 PM)
--DD
What kind of pump are you using there Zack?
Aaron Cox
May 5 2006, 10:41 PM
CB rotary?
are those "pushers" or "pullers" ?
why not mount it up front ?
Hammy
May 5 2006, 10:42 PM
QUOTE(Gint @ May 5 2006, 09:38 PM)
--DD
No idea. Came with the car with carbs.
Does it look fishy?
Gint
May 5 2006, 10:44 PM
QUOTE(Hammy @ May 5 2006, 10:42 PM)
Does it look fishy?
Not at all. It needs to be a low pressure pump for carbs though.
No, I asked because I need to replace the POS facet pump on my carb'd 914.
Hammy
May 5 2006, 10:54 PM
Oh I see
I know there's a part number on it, I can look it up if you want.
I didn't mount it up front because I wasn't sure if I could with this type of pump. (?) I figured if there was a mistake to be made, I would make it.
Also, another fuel question. What exactly is a fuel pressure regulator and what does it do? Ok, obviously it must regulate fuel pressure
. But can someone elaborate? There is/was one hooked up to the fuel line on my car. It looks exactly like
THIS .
So... what is it and is it needed for carbs?
help a newb.
So.Cal.914
May 5 2006, 11:37 PM
Well it is a fuel reg. It is suppose to keep your preasure constant at around 3 1/2
psi. When you turn on your head lamps your pump will slow a bit, at idle it will
slow a bit but when you are freeway flying it will run a little faster. so duering
veriations it was designed to keep the fuel preasure constant. Yes it will be great
for carbs.
MarkV
May 6 2006, 12:48 AM
Looks like the same CB rotary pump that I have. It has an internal regulator so you don't need another one. The nice thing about where you have it mounted is that you can use the factory pump wires & relay to power it. There is a write up in the classic section on how to jumper relay board.
You might want to run a different fuel filter. Those clear plastic ones look fragile to me.
rhodyguy
May 6 2006, 10:55 AM
a little dif appearance wise as compared to my cb. i use a stock fi filter. untimately i lowered mine a bit from the picture to ensure i was lower than the tank outlet. cb are better pushers than pullers. let gravity help from the tank to the pump. you can make a little harness that contects to the stock f.p. wiring and then use andy's method of powering the pump (it will have its own relay and fuse). it solved a fuse issue that plagued me when i was pulling keyed power from the interior fuse panel.
k
Aaron Cox
May 6 2006, 11:38 AM
kevin, why the inline valve?
rhodyguy
May 6 2006, 03:04 PM
i don't have to clamp the fuel line to change the filter. the pump inlet is lower than the tank outlet. if the valve is closed, and the car is unattended for some time, the thief will never get the car to move under it's own power.
k
Hammy
May 6 2006, 03:12 PM
Hey, thanks for the replies everyone.
Do you think I'll have pump problems because of where it's attached?
I only put in about a half gallon of gas in the tank to test it, and it pumped it dry...
rhodyguy
May 6 2006, 03:16 PM
i think it will be ok? did your pump come with the little metal canister that looks like a filter, like mine has?
k
Hammy
May 6 2006, 03:31 PM
QUOTE(rhodyguy @ May 6 2006, 02:16 PM)
k
No.
Andyrew
May 6 2006, 03:35 PM
You'll be fine zack.
If thats an old filter. get a vw stock filter from the place on mchenry. white square thing...
Hammy
May 6 2006, 03:36 PM
QUOTE(Andyrew @ May 6 2006, 02:35 PM)
what place? what part of McHenry?
Andyrew
May 6 2006, 03:44 PM
Vw place. near the elks lodge, right by a cleaners place. down mchenry (going south) on the right.
small place.
but you'll find odds and ends there.
Andrew
rhodyguy
May 26 2010, 02:31 PM
a pretty good oldie.
jeffdon
May 26 2010, 03:24 PM
I have one of these, its always been in the engine comp. right over the pass. side hell hole. Think i may move it down to the lower firewall, looks like a cleaner install.
