Hey guys
Got a 901 side shifter on my 914 engined 550 spyder. I just put a brandwood cable shifter on it, and it seems to work well. Fresh Swepco in there as well.
While adjusting linkage, I found that the the transmission just appears real reluctant to go into 2nd or 4th. I've disconnected the linkage, and I am hard pressed to get the selector on the trans to engage 2nd. Is it possibly stuck? I can shift and drive in other gears (nothing more embarassing than the 1st to 3rd flop with onlookers). If 2nd gear was stuck, should this have freed it? I guess I will take off the access panel (get covered in swepco yet again ) and try to manually select second. Anyone ever see this happen?
Thanks,
DMA
