I have data to support Dave's statement as well. I had a set of 73-74 2.0 and 75-76 2.0 injectors tested, and the reports looked the same. I think they should be interchangable.
PS: If anyone needs a set of cleaned and flow tested good 2.0 injectors PM me. I'm going to put them in the Classifieds when I get around to it.
QUOTE(Dave_Darling @ May 7 2006, 09:49 PM)
Jeff, could you post data that shows the differences? I'd be grateful.
I checked some injectors I had, and found the resistances of the 75-76 ones to be in the same range as the 73-74 ones. And when I had all of the injectors cleaned and tested, they all tested with the same flow rate...
I'd love to see real specs!
--DD
