vesnyder
May 8 2006, 08:46 AM
Installing a new/old thermo and was wondering how much movement I should see from the largest to the smallest - without any spring force on the bellows? I am only seeing about a half an inch? The potential issue is when it is contracted - cold? Does not seem to get max movement out of the cooling flaps. Any experience here?
Joe Ricard
May 8 2006, 09:12 AM
From full cold to full hot is not really that much.
You gain movement from mechanical advantage of the arm on the operating rod of the flappers.
davep
May 8 2006, 12:50 PM
That sounds about right. The collapsed bellows is as small as it gets, and the bellows frame limits the maximum size.
