Full Version: Sway Bars
seanery
This is what I have for the front. My car did not have bars installed before. I have a UTab kit as well as what you see here.
What do the 4 small tabs do?
seanery
Rear. I have the mounting brackets coming.
-P-
I only count 2 bolts for the triangle mounts per side and wouldnt the drop links need bushings?
seanery
complete bushing set is coming. New hardware replaces all old hardware except on bottom shock mount.
Jeffs9146
Are you going to use an inside bracket?
Jeff
seanery
You're thread got me asking this question. I think that may be the only thing I'm missing.
I'll need to get some of those.
Bruce Allert
I made mine. Just found some steel the same thickness as the outside mounts & cut them with a jig saw then drilled the holes. The lower hole was the tricky one tho. Had to use AB epoxy to hold the nut to the plate while I screwed the bolt in from the fender well... and it worked beer.gif
bruce
JWest
The four small tabs go in the arm at the end of the bar to clamp it to the square end. This is a lousy drawing but they are #30:
seanery
Does it go inboard, outboard or in the middle of part #28?
JWest
Here is a better pic:
seanery
so inside the #28 part. That makes sense. I was trying to figure out how that part didn't come off!
Van914
Get busy its been 4 days since you picked up the sway bar. Get it in the car.
Also there is a guy in New Albany, In. who is making the reinforcement plates. I will find his email for you.
Van
Jeff Bonanno
the guy in new albany has them listed in the resources page:
engman's plates
seanery
I ordered his plates as soon as James posted his.
I'll pick them up at Doc & Cy's on Saturday.
Van,
I picked up all the sway bar stuff (F & R) from the blaster today and dropped them off at the powder coater.
I'm getting the brand & part # for the engine tin brad did for me and this stuff will match.
Bruce Allert
shor'du wish'd I'd've known 'bout dem plates fore I made mine. Geeze! dem's nice clap56.gif
bruce
seanery
How long should the bolts be between the two "body mounts" ?
seanery
I just got back from my local CAT dealer. Man, what an awesome vendor! smilie_pokal.gif $3.81 worth of parts and they treat me like a million bucks. I got a couple pages from their parts catalog with part #'s and sizes I'll post later.
I went with 50mm for the above asked question. I hope that's big enough.
