Here's what I built. $3.99 for the gauge, plus shipping. It's brand new, in its original box. With the big face and 60 psi range, it gives great resolution. The company that made it was bought out in 1964, so it's old. I got two to have a backup, and took one apart- very heavy duty all brass construction. No plastic anywhere! Ashcroft made gauges for industrial boilers and the like, so it's unlikely you can even find this quality anymore. Another indicator of its age- the face plate is real glass!!
I got a few fittings at the local NAPA, and attached a leftover piece of 7 x 13 mm fuel line, and I'm rollin'.
He still has 58 of these left. eBay item number 4377179819. Check it out!
Also, I learned something- first, my pressure was set at 35 psi, and it's D-jet. And then, after shutting it off for about a half hour, it was still reading 23 psi. I've never heard any reference to a checkvalve in the fuel pump, but there must be one.... I reset the pressure to just under 30, and it's running better than it has in the 23 years that I've owned it.... Used to smell like a diesel when it idled, not any more. And I gained an inch in idle vacuum besides! Under $10 for that extra inch! What a deal!
(32 psi in the photo was with the engine off, and it was slowly on its way down)
