QUOTE(tdgray @ May 19 2006, 10:18 AM)
Alright you two boobs.
I know what he is asking as I asked this exact question last week.
I never got straight answer either.
I purchased a liquid filled pressure gauge from JEGS and wanted to permanently mount it on the fuel rail. Unfortunately it has a 1/8 NPT on the gauge, so I will need a reducer.
Just don't know what size to go to. Chef... if I figure this out this weekend I will let you know.
Get a 1/8 NPT to 5/16 hose fitting. You then attach a 7.5MM FI hose to it, clamp it securely, taking care not to over tighten it, and slip it onto the fitting provided, again clamping it in place. DO NOT lose the little aluminum washer on the screrw used to plug the fuel line tap! The Cap'n
