QUOTE(Hammy @ May 18 2006, 07:11 PM)
I jumpered pins 30 and 87 on the fuel pump relay port thing...
By power supply i mean where the black relay is plugged in. I've changed around relays and nothing, but I'll keep trying.
ok, a few things ...
- make sure the blue fuse (should be 25 Amp btw.) is good. see if you get 12V to it ...
- if so, remove the red relay and see if you get 12V to the topmost pin (30), that's your 12V supply from the battery.
- make sure your groundwire is *ok*. that crimp connector looks a bit flimsy ...
- check ground connection from the left-center pin (85) on the red relay, it should be connected to your homemade groundwire (this is the former trigger from the FI brain).
- if both check out, the bottom pin (87) should have 12V with the key on, that's your 12V supply to the fuelpump. you can also check pin 13 on the large connector at the top, the one that goes into the main harness. the wire in question is black with a red stripe and it should have 12V with the key on. for this, the red relay has to be in it's socket.
you got a voltmeter, right?
Andy
PS: and none of this will work if the black relay doesn't work correctly. make sure you get 12V from the bottom pin of the black relay (87) to the right-center pin (86) on the red relay. (12V trigger)
