QUOTE(race914 @ Jun 27 2006, 07:48 AM)
Good question! I did try both tops. With the stock top the rear end still gets light and twitchs.
Next experiment is to see what happens to my times at tracks without a high speed sweeper. I'm thinking I might need to use the stock top at Laguna, Thunderhill, etc. if the extra drag of air to the rear spoiler slows me down. Probably only need the vortex generators at Buttonwillow, California Speedway, etc.
Let me know how they work for you
It will be a few months before I have my car back together, but I have 2 tops and will have a huge rear wing at roof height. I intend to try and see the difference on Willow thru T2 and especially T8 sweepers in terms of how they help/hurt airflow to my wing. I have never had a wing before to begin with, let alone tune the airflow to it.
Considering the big difference they seem to make for you, I suspect that they may even
reduce overall drag for you. The tabs add a little drag by punching into the air, but the fact they are apparently combatting the mess that typically happens in the area behind the rear window that wants to lift the back up, they may actually reduce overall drag. Hence why they work for semi trailers to begin with - they drag thru the air but fix the vacuum behind the rear that sucks the truck backwards, hence reducing overall drag and increasing mileage. For us, screw the mileage - we hold power constant (WOT
) and go faster.
At least that is the plan, right
Thanks for letting us all know how it worked out! This may help a lot of us fellow racers quite a bit. I removed my huge spoiler and went to a wing because of lift issues - maybe the spoiler would have been enough if it was actually working. Too late for me find out...
BTW - nice looking car too! Both you and Trekkor have 2 of my favorite, great looking "non-flared" cars.
