Since my daily driver has a blown motor, I decided to use the 1.8 that is a car I am restoring. The engine needed to come out anyway. I really don't like using the floor jack. It seems the height isn't enough and is kinda tippy. It also isn't long enough to reach under the car properly. I decided to make a lifting device. Since the center point is somewhat under the trunk, I made an offset affair using a load leveler I got at HF. This is made from pieces in the scrap box so it does look a little sloppy. I will need to make some improvements before the next drop but it did work real nice. The only problems I had were the usual stuff like engine tin hanging etc. Once I got the motor down a little, I installed 2 rollers on the engine bar. This made for an easy pull from under the car.
Mark
Just before lowering
Engine mounting detail
Engine is hanging
Wheel used to roll out from out from under car
