Borderline
May 20 2006, 07:45 AM
A local guy here has an ad for a 2.0 totally disassembled. He has had the crank ground and has some bearings. He is including the FI which I don't need. He wants $700. I always thought a basketcase would go super cheap. What is it worth?
Thanks,
Bill
Joe Bob
May 20 2006, 07:55 AM
Not 700 bucks.....let HIM rebuild it and sell the finished product.
Tobra
May 20 2006, 08:01 AM
I know a 2.0 with a new top end that the guy was asking $900. Depending on shape of heads, less than $700
gregrobbins
May 20 2006, 08:26 AM
A good set of 2.0L heads are worth $500, I guess it all depends on how complete the rest of the motor parts collection is. You could sell a complete FI system for $150 to $200 and recover a few bucks.
Add up the sum of the parts and that will help you make up your mind.
Joe Bob
May 20 2006, 08:30 AM
QUOTE(gregrobbins @ May 20 2006, 07:26 AM)
True...assuming the heads are rebuildable. Are you experienced enuff to recognize a good head w/o a tear down?
Don't get me wrong....700 is not a bad price, just don't expect a complete and repairable motor for the price. It's a bag of parts and in the long run you will prolly need more parts or a complete engine where these parts will be used....then you sell the extras.
Is it worth the hassle? Not that "I" haven't done it.....
Borderline
May 20 2006, 10:04 AM
No, I don't really have any experience with a 2.0. The heads are off, obviously, what do I look for to make sure they're gud?
rhodyguy
May 20 2006, 10:20 AM
cracks in the combustion chamber, spark plug area. real 2.0 tin should fetch $100+. rods, what ever the market will bear. the ? to ask is where was the crank cut. mains and/or rod journals? 914 pistons? including flywheel, heat exchangers? you can make quite a bit of the price back with known, good fi pieces.
k
boxstr
I just sold a 75 2.0 w/o FI Condition ??? $300.
CCLINMOTORVATOR
So.Cal.914
May 20 2006, 10:28 AM
Well I look for cracks between the valves first, than in other places. Bring a wire
brush and spend a few min's to clean them up a bit first. Than use a thin viscosity
fluid like a solvent, set heads so chambers are up and fill, fill chambers to the top
and let them set for awhile. See if they hold their own water. You can see the fluid
coming out of the ports (intake and exaust) if the valves are bad.
Borderline
May 20 2006, 10:29 AM
Sounds like there is some value there and with the engine in pieces I can inspect it. I'll see if I can haggle him down some...I wonder if he is a non-club member..I doubt it, he would have posted it here.
Thanks for all the help,
Bill
Joe Bob
May 20 2006, 10:40 AM
Cracks in the heads or dropped valve seats are NOT a killer in ALL cases. SOME can be saved.....just more rebuilding costs.
Just remember if it was easy...HE would have rebuild it himself.
newto914s
May 20 2006, 10:50 AM
I thought you were talking $700 for the whole car. $700 for just the engine sounds steep to me.
JPB
May 20 2006, 12:22 PM
I just purchased a complete and runnig 2L engine from a club member for 700$. I say if you have a good 1.7L then rebuild that.
Trekkor
May 20 2006, 12:29 PM
I still have my complete running 2.0 at $1500 for sale.
delivery available.
KT
Andyrew
May 20 2006, 12:48 PM
I sold a 2.0 bout 2 years ago for 600. And there was a reason I sold it for that much. But it did run, drove it every day till I sold it.
It had ORANGE intake runners.
Just fyi..
Mueller
May 20 2006, 01:27 PM
QUOTE(Andyrew @ May 20 2006, 11:48 AM)
Just fyi..
I sold a running, complete motor from '76 2.0 for $1000.....of course I've also sold a complete (basket case) 2.0 motor for $100
