depending on how thin they are, you might not have the option of turning...most shops will not turn a rotor once it's reached it's min. thickness
as copied from Pelican...
the front brake rotors on the 914 should be replaced when they wear past 9.5mm. The rear rotors should be replaced when they wear past 8.5mm. For the 914-6, these wear limits are 18.0mm and 8.5mm.
