jwilliamadams
May 20 2006, 09:47 AM
Greetings,
I have rebuilt my 1.8 and at the same time used new slip in pistons and cylinders that were slightly larger (93x66mm, which I believe works to 1.9+L). The place I purchased them from (West Coast Core in CA) assured me that my L-Jet FI would still work great. Well, I can't get the damn thing to idle. I do not have any vacuum leaks (sure of it.) Timing and dwell are right on. Fuel pressure is good. It runs great past idle with all kinds of power. I have the idle adj screw all the way maxed. At this setting it maybe idles at 700RPM. I have a second air flow meter from same year (1974) that I know works and tried it out with same results. Is it possible that with the new p/c size they are needing more air at idle, more than can be sent through the current idle air port in the throttle assembly?
Thanks for any help!
srb7f
May 20 2006, 10:38 AM
Does it hunt when it idles? The 2.0 I just installed had similar problems with the idle for whatever reason. It wouldn't idle well at all, and would usually stall out any time I pushed in the clutch. The problem ended up being that it was running too lean (even with the adjustment screw all the way rich). The solution for me was to add 3 100 ohm resistors in series with the cyllinder head temperature sensor. This will richen the fuel mixture at idle and under acceleration. Such that you have increased the size of your pistons (in essence adding air) without changing your L-jet (fuel) seems like this might be a problem for you as well. I think the resistors cost me all of $4 at radioshack and another 30 minutes tinkering in the parking lot and I was good to go. Steve
jwilliamadams
May 26 2006, 11:28 AM
It's not hunting. Still not sure what is going on. When I go to time it with a strobe it runs better when the timing is off and worse as I bring the timing mark into view. Very odd. I am going to purchase the compu-fire points/capacitor replacement module today to see if that helps.
Any other ideas anyone?
drewvw
May 26 2006, 11:39 AM
QUOTE(jwilliamadams @ May 26 2006, 10:28 AM)
any chance the dizzy is off by a tooth or two?
Cap'n Krusty
May 26 2006, 11:40 AM
93 mm is stock for a 1.8. Valve adjustment done right (.006"/.006")? Dwell OK, breaker plate ground strap intact? Timing set to 1.8 specs? (Careful, it's done WAY differently from the D-jet cars.) BOTH oil cap seals in good shape? ALL vacuum hoses intact and correctly hooked up? Fix the fundamentals before you throw money at it. Report back. The Cap'n
bd1308
May 26 2006, 02:45 PM
L-jet senses the additional air and accounts for that....
I think its more big-engine friendly.
b
jwilliamadams
May 26 2006, 05:58 PM
drewvw, good question. I guess I assumed that if the gear were off a tooth or two that timing would adjust for that? Should I try to reinstall the drive gear to see if I am off a tooth or two?
Now a new problem. I bought the compu-fire and have it installed but by the time I put the little spacer ring on the shaft, followed by the timing disk (making sure it is all the way seated per instructions) the rotor sits too high and the cap won't seat.
Thanks!
bd1308
May 26 2006, 06:28 PM
I believe some material must be taken off OR you havent seated the magnetic collar down all the way....
b
bd1308
May 26 2006, 06:29 PM
on mine the collar wasnt down all the way...it took some force to get it to snap into place...
b
jwilliamadams
May 27 2006, 10:02 AM
I can't believe this. I just finally re-read every piece of literature I have on timing and am realizing that I have been trying to time to TDC rather than 7.5 BTDC. What a dip. Going out to try this again!
Got the compu-fire timing disk installed. Had to leave out the spacer ring and it worked.
jwilliamadams
May 27 2006, 12:34 PM
Listed my bore wrong up above. It's 96, not 93. So my displacement is 1910cc.
Got it timed to 7.5 BTDC and it is still not idling right.
srb7f
May 27 2006, 03:08 PM
Did you remember to remove and plug both the advance/retard hoses on the distributor before you timed it?
Did you check the alignment of your throttle position sensor at idle? That could also be giving you trouble.
jwilliamadams
May 27 2006, 03:17 PM
I had both hoses plugged. I'll check the TPS. Have not tried that yet. Did verify that fuel pressure is OK. It is (between 30-40psi).
Thanks!
jwilliamadams
May 27 2006, 05:58 PM
Help! I have the engine perfectly timed to 7.5 BTDC now, compu-fire is working great. Fuel pressure is right. The engine is very strong above idle and is fast as hell and drives beautifully. With the big bore p/c I have 1910cc. Is it possible that the idle port is simply not big enough for the extra draw at idle? I ask this because if I bypass the decel valve and just hook a hose directly from the intake air boot to the air distributor of course that gives it more air/fuel and makes it idle at like 2000. I can slip a hose clamp on this hose and tighten it, thereby restricting the airflow and get the idle down to where it should be and it idles fine. This is what makes me think the idle port is too small.
Or am I just out of my mind and the L-jet should be taking everything into consideration, including the extra draw and my problem is still somewhere else?
Thanks
bd1308
May 27 2006, 06:06 PM
take the decel valve out...
jwilliamadams
May 27 2006, 06:15 PM
I tried that too, when I bypassed it as I described above. So is my theory wrong do you think?
bd1308
May 27 2006, 06:24 PM
yeah i think its a little off. The 912E used the 2.0 914 engine and used the L-jet system off of the 1.8. I've been told and it made sense to me that porsche built the 912E to get rid of the extra 914 engines they had.
Okay, so what I would look for is vacuum leaks. I had a leak in the boot and it caused a horribly LOW idle, which of course was also lean as well.
Your idle adjustment screw is on the throttle body.
I went to my FLAPS and bought a full container of plugs that covered up and sealed those ports in the plenum. I didnt need to complicate things just yet. K.I.S.S. method at work here
Anyway,I did get it to idle after some electrical issues and once it idled, I continued to look for leaks until it idled well (idled well at 1100 warm)
Then one by one i connected the tubes until I got everything to work.
Start simple and work your way up.
b
Joe Bob
May 27 2006, 06:27 PM
Ummm, isn't this where ya check the oil cap gasket and go...DOH?
Oh yeah...LIGHTLY spray carb cleaner or ether/quickstart around known to leak areas.....when the idle changes...ya gots a leak....
Cap'n Krusty
May 27 2006, 06:40 PM
Tell us HOW you set the timing. Did you follow the L-jet procedure? As I said earlier, it's very different from the D-jet procedure. The Cap'n
srb7f
May 27 2006, 07:27 PM
Does adjusting the idle screw have any effect on idle speed? If not, have you looked closely at the throttle body to make sure that the idle ports are not clogged?
jwilliamadams
May 28 2006, 10:52 AM
The timing is adjusted to 7.5 BTDC. I originally had that wrong and had it adjusted to TDC like an ass. But I finally read everything again, used the impeller template from the bird site to find 7.5 BTDC and marked it. Vacuum hoses disconnected from the dizzy. Of course, have to crack the throttle ever so slightly to get it to run between 800-900 rpms to set it right. The only thing I have not done yet is make sure TDC on the flywheel agrees with TDC on the impeller. Will do that today.
I took the idle screw all the way out to make sure the idle port is clear, and it is.
Thanks all.
jwilliamadams
May 28 2006, 01:43 PM
I have found the notch in my flywheel and lined it up top to the crack in the case for TDC for #1. When I look at my impeller now, the one and only notch in my impeller is exacly 7.5 degrees BTDC, not TDC. So yesterday when I used the template on the PP site to mark 7.5 BTDC with the notch as my starting point, it appears that the mark I made would actually be 15 degrees BTDC, not 7.5.
If my impeller notch is in fact 7.5 BTDC then I should be timing with the strobe to that mark, right?
What notch do I go with to indicate TDC? The flywheel notch lined up to case crack or the impeller notch lined up with the V in the fan housing?
Cap'n Krusty
May 28 2006, 03:11 PM
QUOTE(jwilliamadams @ May 28 2006, 12:43 PM)
The flywheel notch should be fine. If it matches the fan notch, then the fan notch is TDC as well. If not, then the fan notch is the timing mark. You STILL haven't told us the technique yiou used to set the timing. If you used the conventional (D-jet) method, it'll never run right. The Cap'n
jwilliamadams
May 28 2006, 04:58 PM
Cap'n, I used the L-Jet 1.8 procedure for timing. It's timed to 7.5 degrees BTDC at 850 RPM with hoses removed from the dizzy and plugged. I now understand that my notch on the impeller is my timing mark of 7.5 BTDC.
I just re re rechecked all my hoses and they are all tight. Oil filler cap has a new gasket and o ring and is tight. I checked my valve adjustment this morning for kicks while I was finding the flywheel notch and they are all good at .006 in.
Running out of ideas.....
