Scott is not joking! Take the arm outside to a well ventilated area and use a propane torche to ignite the rubber bushing. It will burn easily and when done you will just have some ashes to contend with. Watch those dripping fireballs of rubber. They will make a mess of your driveway or back patio. Put a old cookie sheet under the burning mess to catch these fireballs. After all has cooled, clean up the arm with a Scotch Brite pad and repaint prior to putting in your new bushings.
QUOTE(ty914 @ May 20 2006, 10:49 AM)
I have found plenty of info and "how 2's" on removing and replacing the front bushings but have found no info on the rear.
A little info on roller bearings...but need some help on removing the old bushings first. Did a few searches and didn't come up with anything...
Any help would be much appreciated...
Thanks...T
