propricer
May 20 2006, 11:09 AM
Never heard of this one until it happened to me ... anyone ever have the clutch pivot ball break off right at its base ??? Running a 911 pull type clutch on my V8 / 901.
I've had the ball pull out of the case a couple of times and have fixed that one for good but this is a new one.
Anyone ever had this happen ... with the clutch fork now floating, did it also take out the pressure plate ???
Thought this was a hardened part ... boy, what a NOISE when it went !!!
Mark Henry
May 20 2006, 11:17 AM
Most likely it's only the ball...it makes one hell of a bang, but it should be the only thing broke.
Mark Henry
May 20 2006, 11:23 AM
BTW I've had to do this repair on 2 customers cars in the last 2 years, both pull type. Is your pedal real hard? Check your cable for binding.
Also do you have a pedal board?
Cap'n Krusty
May 20 2006, 11:41 AM
Common 2.2 911 failure. I've probably seen a dozen or more over the years. There have been numerous products on the market that attempt to address the problem, but I can't attest to whether or not they work. Might wanna check the thickness of the disc: major reason for the failure of the pivot. The Cap'n
