Ok, the PO put in a hot start relay down by the starter. At least that's what I've been told it is.
It has worked just fine, no problems.
I recently pulled my starter becuase it was having problems. In pulling out the starter I "think" i pulled some cables out of the block that connects to the relay.
Coming off or thru the tin, I have three wires; A black and a red, both with circular connectors. These go to the post on the starter. No problem. The other wire is actually 3 wires, all brown casing. Once goes into the relay. The other two have an odd termination on the end.
I have attached pix to show some of what I am seeing. Camera takes crappy pix upclose, so I apologize.
The relay and the block where everything connects.
The funky looking terminations. These are the 2 wires I have no idea where they go.
I am looking for help to fix or remove this setup.
Thanks in advance.
