QUOTE(turboman808 @ May 20 2006, 06:00 PM)
I was told to get NGK8 which doesn't mean a whole lot to the Strauss. So I figure I would order them on EBAY. SO I am wondering what I need to get.
Anyways it's a 2.7 RS motors. I would prefer to get iridium NGK sparkplugs. I have had very good luck with them.
So can anyone help a brother out
So you have a 2.7L Mechanical Fuel Injection motor? The recommended plug is a Bosch W3DP0. Difficult plug to find. Might try an NGK BP7ES or a BP8ES. FWIW, this is a motor that doesn't like to be driven as a daily driver, doesn't like to be driven in traffic, and needs the revs kept up in the 4-5000 RPM range when you have any significant load on it. It tends to foul plugs when not being pushed a bit. That's why the special cold platinum plugs, which are used in very few other cars. They are NOT the same as the cheap and readily available Platinum plugs, and they list for $29.40 EACH. I can get them for you, and at a substantially better price. The Cap'n
