nine14cats
May 21 2006, 02:00 PM
I would like to replace my brake lines in my 914 with new ones. All new runs from M/C to the wheels.
Where do I get the hard line? Is is stainless?
Do I just buy bulk stock and bend and flare the tubes to fit?
Thanks,
Bill P.
LowGT
May 21 2006, 02:16 PM
I replaced the front ones. I bought pre-flared lines and bent them myself, I'm pretty sure you won't find pre-bent lines anywhere. Mine weren't stainless but it didn't bother me since rust isn't an issue in this area.
I saw an evilbay auction for a complete set of pre-flared lines. You just have to bend them. I don't know anything about the seller or the quality of the line though.
Dan
lapuwali
May 21 2006, 02:34 PM
Bill, your FLAPS will have flared hard lines with the correct end fittings in various lengths, unbent. Just measure, buy, and bend to fit. I did this on one of my rear hard lines recently, when a fitting broke. The FLAPS lines was almost exactly the right length, and bending it to very close to the stock shape was quite easy (as in no tools reaquired, just use your hands).
nine14cats
May 21 2006, 02:44 PM
Thanks Guys!
Bill P.
jr91472
May 21 2006, 05:56 PM
Got mine at Autozone. Take an old one with you and make sure you get the right fittings
jd74914
May 21 2006, 06:07 PM
Yep thats exactly what I did last weekend. I even got them @ Autozone.
echocanyons
May 21 2006, 06:21 PM
Slight hijack.
Do you really need the bends like the factory cars in the rear trailing arms? It seems as though the brakeline movement is all by the soft lines.
Are there any worries or safety issues with using a straight shot or nearly straight shot to the caliper?
jd74914
May 21 2006, 06:35 PM
QUOTE(echocanyons @ May 21 2006, 08:21 PM)
Slight hijack.
You don't need all of those bends. A few are necessary but a bunch aren't so necessay at least IMHO. I didn't put them all back in. I didn't go with a totally straight shot either tho.
wilchek
May 21 2006, 06:53 PM
Spend a couple bucks more and get a bedning tool. Easy hand held device that assures a correct bend and no pinching.
