I think the wiring on my Cylinder Heat Temp Sensor is shot. As an interim measure, I'd like to see if I can wire directly from the sensor pigtail to the ECU. Looking at the wiring diagram at Pelican Parts I'm thinking that the CHT is probably #77, which connects to pin 23 on the ECU. The legend for the wiring diagram simply says that #76 & #77 are temperature sensors so I'm not sure which is the one I want.
Anybody know what pin on the ECU the CHT sensor connects to?
