1973 2.0L with stock D-Jet fuel injection.
About a month ago I had a strange occurance on the way to work. Engine ran smooth as usual until about 2 blocks away from the house when it cut out/in with no other symptoms. I pulled over, checked every connection on the engine that I could find, but nothing is obviously loose. Try it again, but the problem is still there so I stop for about 20 minutes at a store and when I come out and try it again it runs fine.
It has run fine ever since - even did 300 miles for the Route 66 Classic - but now the problem is back. My first thought was that it must be my home made resistor in the CHT sensor circuit, but removing the resistor didn't help. Completely bypassing the CHT sensor circuit with a new wire to the ECU didn't change it either.
I'm stumped This is not the kind of "buck" that you get at steady speed when the Throtte Position Switch is worn - it's a total shut down of the engine that can come right back as if some connection is vibrating loose and then reconnecting. Besides the CHT, what other components might cause this behavior?
