So I have a converted renegade 930 and have worked through testing my vehicle speed sensor. The tests show the fault is in the trans. The pick up in the trans works but there may or may not be any magnets installed.
The pick up is a reed valve which is pulled down by the magnets and the reason I know it's (the pick up) good is I am able to trigger it with a large magnet from outside the transmission. I can get another reed valve trigger and try to duplicate the mag/pick up using magnets on the CV joint flange.
Brain storming needed...
