QUOTE(1970 Neun vierzehn @ May 22 2006, 02:20 PM)
Did the factory install the radio antenna? The dealer? Or maybe both? And where is the correct site for installation? Left or right front fender? And whose brand....Hirschmann? Motorola? It almost seems as if it is period-correct, it would be OK. There probably was a lot of dealer discretion in this area.
Dealer did.......Some on occasion would put on psngr side by mistake...
The exit hole is in the dash area..(by the fresh air intake fan)
which on occasion would get caught up in the fan cables and raise havoc..
Then goes left to the hole in and thru
the driver side fender..Naturally with the appropriate rubber body washers.
Motorola ..Blaupunkt..Craig 8 tracks ..such as my 75 has with no hole and a
window antenna....As the dealer saw fit or requested ahead by the customer..
Hard to find an original in these cars anymore...On a local scale show not a real
point buster..National ..Yes!!
Models on the anntenna's....Hirsh seemed to be the most popular..
Most of them 'freeze up'.. and get replaced..Very hard to find an original on those..
Pat is yours still Original??
