Allan
May 22 2006, 06:23 PM
As alot of you know. I finally took the six out for a semi-actual a/x this last weekend. The weather was 85 - 90 degrees with warm winds blowing at 30 - 50 mph.
I made four 2 mile runs and even sat idling between runs and my oil temp never got above 210.
I have a 2.7 conversion with RS pistons, Solex cam, with right at 10 to 1 compression running premium pump gas.
Am I lucky or is this the norm? When is an external cooler needed?
Dr Evil
May 22 2006, 07:22 PM
Your gauge is broken
Aaron Cox
May 22 2006, 07:39 PM
it cant hurt. use a t stat...
and yes... you will find you need one when at button willow in june....
michel richard
May 22 2006, 08:00 PM
I think the quick and dirty answer is that you need them when your HP exceeds something like 170.
736conver
May 22 2006, 08:39 PM
I have a stock 3.2 and have yet to go over 210. No extra cooler. I havent seen any air temps past 80 up here yet, so time will tell.
But like Aaron said it cant hurt.
Trekkor
May 22 2006, 09:40 PM
My personal experience is you will need one if you track the car.
KT
DanT
May 22 2006, 09:42 PM
QUOTE(trekkor @ May 22 2006, 08:40 PM)
KT
Gee, where have I heard that before?
turboman808
May 22 2006, 09:50 PM
I haven't seen 85-90 yet. Most of the time I wonder when it's gonna warm up. Thing hasn't hit 200 yet. It has a cooler mounted in the back with fans but I haven't turned it on yet. 2.7 motor with 3.2 oil pump.
Yeah when I drove it in traffic the other day it didn't warm up to 180 for 15 minutes.
campbellcj
May 22 2006, 09:59 PM
Street or autocross use is very different from driving at 5000-7000 rpm's for 20-30 minutes. Especially when it's >90F outside.
Allan
May 22 2006, 10:02 PM
QUOTE(michel richard @ May 22 2006, 07:00 PM)
I'm already over 200...
Aaron Cox
May 22 2006, 10:04 PM
you will find yourself running hot at buttonwillow.....
