seanery
Sep 26 2003, 08:35 AM
This looks like a pretty good deal to me
Euro 2.0 Pistons & Cyls
Charles Deutsch
Sep 26 2003, 09:11 AM
"Our Piston Manf. currently uses gravity feed permanent molds to produce aluminum pistons."
I watched a car show just last weekend that talked about the casting and forging of parts. The "least good" method was gravity feed casting because it can leave tiny air bubbles in the part, vacuum casting was better and forging was best. Aren't the OEM pistons forged?
maf914
Sep 26 2003, 09:24 AM
What makes these "European Spec"? Just loose use of that favorite marketing phrase? I thought what we refer to as Euro spec P/Cs were for 2.0Ls and were 8:1 compression ratio. These claim to be 9.2:1.
Mike
Mueller
Sep 26 2003, 09:33 AM
"euro" spec is sorta generic now with the 2.0 p/c's
basicly, higher compression (by means of a flat top piston)
the compression can eaisly be raised or lowered via the gaskets/shims...
but who knows if thier figures are using what combo of gaskets/shims???
Brad Roberts
Sep 26 2003, 01:25 PM
I'll let you know real soon how these work.
B
Jeff Bonanno
Sep 26 2003, 01:29 PM
Brad,
which car did you put them into? i thought you put 96s into your wife's?
Brad Roberts
Correct.. but from the same company.
B
seanery
Sep 26 2003, 07:41 PM
the 96's they sell on ebay look like they have a lower CR.
