QUOTE(Grngoat @ May 22 2006, 08:50 PM)
Yeah, it's pretty easy. You'll have to disconnect it from the pedal end first. There's a snap retainer thingy that you pop off, then unscrew the end so it's just a cable with a threaded end. Can be crowded working in the footwell. Then disconnect the end from the clutch fork and the whole thing slides out from the engine bay side. Replacing is the reverse, slide it in from the engine side, screw on the tunbuckle end, connect to the pedal and snap the retainer back on. Then climb to the back and wrap the cable around the pulley and connect to the clutch fork. Adjust the cable and you're done.
sweetness.
I was kind of looking for an excuse to drop the engine...
