Thack
May 24 2006, 07:47 PM
Why would the Compu-fire magnetic pickup be different from a Bosch 009 distrib and a vac advance one?
lapuwali
May 24 2006, 07:50 PM
The Compufire is meant to mount to the points plate just like a set of points. The points plate on the 009 is different from the vacuum advance distributor you're thinking of (there are actually quite a few that will fit).
john rogers
May 24 2006, 08:38 PM
The difference between the two models is the height of the rotating plate with the 4 magnets. The top of one fits higher than the other, sorry I forget which is taller but if use the wrong one either there will be no spark or the center button in the cap will be crushed.
Thack
May 24 2006, 10:41 PM
I once used a cheap Accu-fire. After it got warm it started to rub and would not fire. But the accu-fire has only one part for the bosch distributor. Thanks for the tip. I can work with that.
