OK Maybe someone has run into this.
I was installing my tail lights yesterday. Had to figure out the wiring. As usual the Haynes manual was pratically worthless.
Think I have it all figured out.. at least everything is working as it should on the outside.
Here's the problem. When I turn my turn signals on the seat belt warning light flashes along with it, both directions.
But, here's more wierdness, the turn indicator on the tach will work correctly if I turn the drivers side TS on. If I turn the pass side TS on the indicator in the tach flashes as if I have the hazard switch on (you know both arrows).
Note: everthing is working outside the car just fine. Just not inside.
Also... where is that F&#$(&ing seat belt buzzer so I can disconnect the damn thing. Really F'in annoying.
EDIT - Oh and I just noticed that the hazard switch is not working.
